이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
필요한 것
In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
