주요 콘텐츠로 건너뛰기
How to clean Nokia 3120
필요한 것
  1. How to clean Nokia 3120, Battery Installation: 1 단계, 이미지 3개 중 1개 How to clean Nokia 3120, Battery Installation: 1 단계, 이미지 3개 중 2개 How to clean Nokia 3120, Battery Installation: 1 단계, 이미지 3개 중 3개
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. How to clean Nokia 3120: 2 단계, 이미지 1개 중 1개
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. How to clean Nokia 3120, Face Plate: 3 단계, 이미지 3개 중 1개 How to clean Nokia 3120, Face Plate: 3 단계, 이미지 3개 중 2개 How to clean Nokia 3120, Face Plate: 3 단계, 이미지 3개 중 3개
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. How to clean Nokia 3120, How to clean Nokia 3120: 4 단계, 이미지 1개 중 1개
    • If dirt has gotten inside the phone, both the lens and the case should be cleaned.
    • Once the screen is exposed, spray cleaning solution onto a soft cloth and wipe the screen.
    • Make sure to thoroughly dry the screen.
  5. How to clean Nokia 3120: 5 단계, 이미지 1개 중 1개
    • Repeat the cleaning process on the clear plastic connected to the face-plate.
    • If the screen still appears dirty after a thorough cleaning, parts may have to be replaced. See the troubleshooting guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rashmili Vemula
회원 가입일: 03/11/13
23 평판
안내서 1개를 작성함
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 회원
CLEM-BENSON-S13S13G2
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 1,098
