주요 콘텐츠로 건너뛰기
How to clean Non-functoning buttons on remote
필요한 것
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: 1 단계, 이미지 1개 중 1개
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: 2 단계, 이미지 2개 중 1개 How to clean Non-functoning buttons on remote: 2 단계, 이미지 2개 중 2개
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: 3 단계, 이미지 1개 중 1개
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: 4 단계, 이미지 2개 중 1개 How to clean Non-functoning buttons on remote: 4 단계, 이미지 2개 중 2개
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: 5 단계, 이미지 1개 중 1개
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
결론
다른 23명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
andre
회원 가입일: 03/12/12
1,800 평판
안내서 4개를 작성함
29가이드 댓글
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - 답글
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - 답글
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - 답글
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 36
지난 30일: 134
전체 시간: 38,899
