주요 콘텐츠로 건너뛰기
How to clean Panasonic SA-HT810V DVD Optical Head
필요한 것
  1. How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: 1 단계, 이미지 3개 중 1개 How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: 1 단계, 이미지 3개 중 2개 How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: 1 단계, 이미지 3개 중 3개
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean Panasonic SA-HT810V DVD Optical Head: 2 단계, 이미지 2개 중 1개 How to clean Panasonic SA-HT810V DVD Optical Head: 2 단계, 이미지 2개 중 2개
    • Rotate the device so that the back faces you.
    • With a phillips head screw driver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean Panasonic SA-HT810V DVD Optical Head: 3 단계, 이미지 1개 중 1개
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean Panasonic SA-HT810V DVD Optical Head: 4 단계, 이미지 3개 중 1개 How to clean Panasonic SA-HT810V DVD Optical Head: 4 단계, 이미지 3개 중 2개 How to clean Panasonic SA-HT810V DVD Optical Head: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Before cleaning DVD lens, make sure that the front of the device is facing towards you.
    • Note that the DVD component of the device is boxed in red.
    • To access the DVD lens, spin the gear circled in image two counter-clockwise until the lens is exposed.
    • Clean the lens by GENTLY rubbing with a microfiber cloth and a cleaning solution of your choice.
결론
작성자
6다른 기여자 명과 함께
Nathan Cheadle
회원 가입일: 04/15/10
161 평판
안내서 7개를 작성함
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 2,428
