주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide contains photos that do not include pictures of the back cover or battery. However, the instructions have been adjusted to reflect this lack of visual aid.
  1. Flip the phone over and take off the back cover
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Use button to remove battery from the phone.
    • Use button to remove battery from the phone.
  3. Locate the six (4mm) screws on the back casing of the phone. Unscrew each one using a phillips head #000 screwdriver. Place screws on magnetic mat.
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  4. Starting at the top of the phone, carefully insert plastic opening device into the seam. Carefully slide device along the seam and around the corners of the phone until the back is separated from the front. Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  5. Locate the connection point of black wire running from the microphone to the motherboard. Carefully disconnect the gold connector from the motherboard using tweezers. Carefully disconnect the gold connector from the motherboard using tweezers.
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  6. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  7. Locate the red connector at the top of the motherboard. Carefully lift and remove the connector from the motherboard using tweezers. Carefully lift and remove the connector from the motherboard using tweezers.
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  8. Locate the gold connector that connects the screen to the motherboard. Carefully disconnect the connector from the motherboard using tweezers. Carefully disconnect the connector from the motherboard using tweezers.
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  9. Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool. Lift the motherboard from the cell phone. Lift the motherboard from the cell phone.
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  10. Remove the motherboard from the cell phone.
    • Remove the motherboard from the cell phone.
  11. Locate the two black, rubber tabs near the top of the back of the phone. Locate the one black, rubber tab near the base of the phone.
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  12. Using tweezers, pry each of the tabs open. Tuck each tab behind the white notch. By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  13. Flip phone over to make the keypad visable. Carefully lift keypad around the edges. Remove keypad from the cell phone.
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
  14. Obtain device cleaner and a cleaning pad.
    • Obtain device cleaner and a cleaning pad.
  15. Spray the front of the keypad with device cleaner. Clean front of keypad using cleaning cloth. Clean front of keypad using cleaning cloth.
    • Spray the front of the keypad with device cleaner.
    • Clean front of keypad using cleaning cloth.
  16. Flip keypad over. Spray back of keypad with device cleaner. Clean back of keypad with cleaning cloth.
    • Flip keypad over.
    • Spray back of keypad with device cleaner.
    • Clean back of keypad with cleaning cloth.
결론
Yi Ren
회원 가입일: 2014년 03월 26일
801 평판
안내서 8개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 회원
CLEM-BENSON-S14S1G4
3 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 126
