주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
How to clean Samsung SGH-T639 keypad
필요한 것
  1. How to clean Samsung SGH-T639 keypad, Battery: 1 단계, 이미지 1/1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. How to clean Samsung SGH-T639 keypad: 2 단계, 이미지 1/1
    • Use button to remove battery from the phone.
  3. How to clean Samsung SGH-T639 keypad, Motherboard: 3 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad, Motherboard: 3 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad, Motherboard: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  4. How to clean Samsung SGH-T639 keypad: 4 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 4 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 4 단계, 이미지 3/3
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  5. How to clean Samsung SGH-T639 keypad: 5 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 5 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 5 단계, 이미지 3/3
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  6. How to clean Samsung SGH-T639 keypad: 6 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 6 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 6 단계, 이미지 3/3
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  7. How to clean Samsung SGH-T639 keypad: 7 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 7 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 7 단계, 이미지 3/3
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  8. How to clean Samsung SGH-T639 keypad: 8 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 8 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 8 단계, 이미지 3/3
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  9. How to clean Samsung SGH-T639 keypad: 9 단계, 이미지 1/1
    • Remove the motherboard from the cell phone.
  10. How to clean Samsung SGH-T639 keypad, Keypad: 10 단계, 이미지 1/2 How to clean Samsung SGH-T639 keypad, Keypad: 10 단계, 이미지 2/2
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  11. How to clean Samsung SGH-T639 keypad: 11 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 11 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 11 단계, 이미지 3/3
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  12. How to clean Samsung SGH-T639 keypad: 12 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 12 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 12 단계, 이미지 3/3
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
  13. How to clean Samsung SGH-T639 keypad, How to clean Samsung SGH-T639 keypad: 13 단계, 이미지 1/1
    • Obtain device cleaner and a cleaning pad.
  14. How to clean Samsung SGH-T639 keypad: 14 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 14 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 14 단계, 이미지 3/3
    • Spray the front of the keypad with device cleaner.
    • Clean front of keypad using cleaning cloth.
  15. How to clean Samsung SGH-T639 keypad: 15 단계, 이미지 1/3 How to clean Samsung SGH-T639 keypad: 15 단계, 이미지 2/3 How to clean Samsung SGH-T639 keypad: 15 단계, 이미지 3/3
    • Flip keypad over.
    • Spray back of keypad with device cleaner.
    • Clean back of keypad with cleaning cloth.
결론
Yi Ren
회원 가입일: 03/26/14
801 평판
안내서 8개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 회원
CLEM-BENSON-S14S1G4
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 207
