이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Locate the six (4mm) screws on the back casing of the phone.
Unscrew each one using a phillips head #000 screwdriver.
Place screws on magnetic mat.
Starting at the top of the phone, carefully insert plastic opening device into the seam.
Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
Locate the connection point of black wire running from the microphone to the motherboard.
Carefully disconnect the gold connector from the motherboard using tweezers.
Locate the red connector at the top of the motherboard.
Carefully lift and remove the connector from the motherboard using tweezers.
Locate the gold connector that connects the screen to the motherboard.
Carefully disconnect the connector from the motherboard using tweezers.
Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
Lift the motherboard from the cell phone.
Locate the two black, rubber tabs near the top of the back of the phone.
Locate the one black, rubber tab near the base of the phone.
Using tweezers, pry each of the tabs open.
Tuck each tab behind the white notch.
Flip phone over to make the keypad visable.
Carefully lift keypad around the edges.
Remove keypad from the cell phone.
Spray the front of the keypad with device cleaner.
Clean front of keypad using cleaning cloth.
Flip keypad over.
Spray back of keypad with device cleaner.
Clean back of keypad with cleaning cloth.
