주요 콘텐츠로 건너뛰기
How to clean Sony CCD-TR81 viewfinder
필요한 것
  1. How to clean Sony CCD-TR81 viewfinder, Disassembling Sony CCD-TR81 Battery: 1 단계, 이미지 1/1
    • Lift viewfinder to access battery pack.
  2. How to clean Sony CCD-TR81 viewfinder: 2 단계, 이미지 1/2 How to clean Sony CCD-TR81 viewfinder: 2 단계, 이미지 2/2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. How to clean Sony CCD-TR81 viewfinder: 3 단계, 이미지 1/1
    • Pull the battery pack out of the video camera.
  4. How to clean Sony CCD-TR81 viewfinder, How to clean Sony CCD-TR81 viewfinder: 4 단계, 이미지 1/1
    • Pull the viewfinder eyepiece out and away from the main video camera until the black mark appears.
  5. How to clean Sony CCD-TR81 viewfinder: 5 단계, 이미지 1/1
    • Twist the eyepiece counterclockwise until it stops.
  6. How to clean Sony CCD-TR81 viewfinder: 6 단계, 이미지 1/1
    • Pull the eyepiece completely off away from the rest of the viewfinder.
  7. How to clean Sony CCD-TR81 viewfinder: 7 단계, 이미지 1/2 How to clean Sony CCD-TR81 viewfinder: 7 단계, 이미지 2/2
    • Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder.
  8. How to clean Sony CCD-TR81 viewfinder: 8 단계, 이미지 1/1
    • Use a cleaning cloth to wipe away residue from the viewfinder.
결론
Kevin
회원 가입일: 01/24/11
232 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-25, Maness Winter 2011 Cal Poly, Team 11-25, Maness Winter 2011 회원
CPSU-MANESS-W11S11G25
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 3,888
