주요 콘텐츠로 건너뛰기
How to clean TI-Nspire buttons
필요한 것
  1. How to clean TI-Nspire buttons, How to clean TI-Nspire buttons: 1 단계, 이미지 1/1
    • Turn the calculator over so that the blue Texas Instruments logo is up.
    • Slide the blue case downward until it is completely removed from the calculator.
  2. How to clean TI-Nspire buttons: 2 단계, 이미지 1/1
    • Step 2 and 3 to detach the keyboard are optional, but may prevent permanent damage to the calculator.
    • Turn the calculator over and locate the sliding latch on the back of the calculator.
  3. How to clean TI-Nspire buttons: 3 단계, 이미지 1/2 How to clean TI-Nspire buttons: 3 단계, 이미지 2/2
    • At the same time, slide the latch to the right and pull the keypad downward. This should completely separate the keypad from the calculator.
  4. How to clean TI-Nspire buttons: 4 단계, 이미지 1/1
    • Now that you have detached the keypad, gather the cotton swabs and rubbing alcohol.
    • Dampen a cotton swab by placing 1 to 3 drops of rubbing alcohol on the tip.
    • Be careful not to completely soak the the cotton swab with the rubbing alcohol.
    • DO NOT pour the rubbing alcohol directly onto the keypad. Too much liquid exposure can permanently damage it.
  5. How to clean TI-Nspire buttons: 5 단계, 이미지 1/1
    • Use the moistened cotton swab and rub it around each button, in crevices, and anywhere on the keypad that may have dirt. Replace the swab as often as desired.
    • Keep the rubbing alcohol away from the calculator's visual display. Water exposure to the screen can permanently damage the screen.
결론
Now your buttons should be free of any stickiness.
Mariel Sanchez
회원 가입일: 09/27/12
22 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 5,704
