주요 콘텐츠로 건너뛰기
How to clean a Game Boy Cartridge
필요한 것
  1. How to clean a Game Boy Cartridge, How to clean a Game Boy Cartridge: 1 단계, 이미지 1개 중 1개
    • First obtain a cartridge. This is where games for the Game Boy are located.
  2. How to clean a Game Boy Cartridge: 2 단계, 이미지 1개 중 1개
    • Place cartridge into cartridge reader slot on the back of the Game Boy system.
    • The game graphic should be facing towards you when you place the cartridge into the reader slot.
  3. How to clean a Game Boy Cartridge: 3 단계, 이미지 2개 중 1개 How to clean a Game Boy Cartridge: 3 단계, 이미지 2개 중 2개
    • Push down until the game "locks" into place, and the top of the game is a small amount beneath the top of the system.
  4. How to clean a Game Boy Cartridge: 4 단계, 이미지 1개 중 1개
    • If game does not load when the system is turned on, turn off system and remove cartridge.
    • Remove cartridge by placing thumb on the outside of the cartridge near the indentation and pushing up. Dislodging the cartridge from the cartridge reader.
  5. How to clean a Game Boy Cartridge: 5 단계, 이미지 2개 중 1개 How to clean a Game Boy Cartridge: 5 단계, 이미지 2개 중 2개
    • Apply some air into the cartridge bottom and into the cartridge reader itself.
    • Reinsert cartridge and try again.
    • If problem still persists, an internal problem may be the culprit.
결론
To play another game, remove cartridge and place new one in cartridge reader.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Tramposch
회원 가입일: 06/24/10
2,273 평판
안내서 6개를 작성함
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 36개를 작성함
5가이드 댓글
Step one: blow into the game
Bry W - 답글
This guide is completely unhelpful with how to clean a GameBoy game.
It would be better to refer to these videos on how to clean old game cartridges:
- https://www.youtube.com/watch?v=K4SCpHgW...
- https://www.youtube.com/watch?v=4Ej2Y2ch...
Ervin - 답글
Nothing like a good ol’ blow job to get those old cartridges feeling new again.
Igor Kolosha - 답글
my copy of frogger 2 still wont work
mail jack - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 90
전체 시간: 22,298
