주요 콘텐츠로 건너뛰기
How to clean a Game Boy Cartridge
  1. How to clean a Game Boy Cartridge, How to clean a Game Boy Cartridge: 1 단계, 이미지 1/1
    • First obtain a cartridge. This is where games for the Game Boy are located.
  2. How to clean a Game Boy Cartridge: 2 단계, 이미지 1/1
    • Place cartridge into cartridge reader slot on the back of the Game Boy system.
    • The game graphic should be facing towards you when you place the cartridge into the reader slot.
  3. How to clean a Game Boy Cartridge: 3 단계, 이미지 1/2 How to clean a Game Boy Cartridge: 3 단계, 이미지 2/2
    • Push down until the game "locks" into place, and the top of the game is a small amount beneath the top of the system.
  4. How to clean a Game Boy Cartridge: 4 단계, 이미지 1/1
    • If game does not load when the system is turned on, turn off system and remove cartridge.
    • Remove cartridge by placing thumb on the outside of the cartridge near the indentation and pushing up. Dislodging the cartridge from the cartridge reader.
  5. How to clean a Game Boy Cartridge: 5 단계, 이미지 1/2 How to clean a Game Boy Cartridge: 5 단계, 이미지 2/2
    • Apply some air into the cartridge bottom and into the cartridge reader itself.
    • Reinsert cartridge and try again.
    • If problem still persists, an internal problem may be the culprit.
    Please don't blow in it.
    Use compressed air, or clean the pins with 90+% isopropyl alcohol.
    Harley - 답글
결론
To play another game, remove cartridge and place new one in cartridge reader.
다른 17명이 해당 안내서를 완성하였습니다.
Andrew Tramposch
회원 가입일: 06/24/10
2,234 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 34개 작성하였습니다
댓글 5개
Step one: blow into the game
Bry W - 답글
This guide is completely unhelpful with how to clean a GameBoy game.
It would be better to refer to these videos on how to clean old game cartridges:
- https://www.youtube.com/watch?v=K4SCpHgW...
- https://www.youtube.com/watch?v=4Ej2Y2ch...
Ervin - 답글
Nothing like a good ol’ blow job to get those old cartridges feeling new again.
Igor Kolosha - 답글
my copy of frogger 2 still wont work
mail jack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 35
30일 전: 159
전체 시간: 20,003
