주요 콘텐츠로 건너뛰기
How to clean a rusting Microwave
필요한 것
  1. How to clean a rusting Microwave, Prepare the surface: 1 단계, 이미지 1개 중 1개
    • Unplug the microwave oven.
    • Clean the surface of all grease residue with alcohol or acetone.
  2. How to clean a rusting Microwave, Remove the rust: 2 단계, 이미지 1개 중 1개
    • Remove the glass tray and roller ring
    • Remove the stuck rust with steel wool.
    • Wipe away any debris with a dry cloth
  3. How to clean a rusting Microwave, Apply the paint: 3 단계, 이미지 1개 중 1개
    • Shake the tin
    • Apply a thin coat with the brush
    • Give the paint at least 6 hours to dry
    • Apply 1 or 2 more coats as appriopriate
  4. How to clean a rusting Microwave, Replace tray: 4 단계, 이미지 1개 중 1개
    • Allow time for the paint coatings to dry properly, ideally overnight with the door open.
    • Replace roller ring and tray. Plug your oven to the power outlet.
    • You are now ready to use your microwave oven again!
결승점
다른 21명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tristan Hill
회원 가입일: 08/31/15
600 평판
안내서 1개를 작성함
4가이드 댓글
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
wgcormier - 답글
Thank you for the information.
Marci B Jeffcoats - 답글
Where do I buy the special paint
Diane Sauchuk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 143
전체 시간: 63,605
