주요 콘텐츠로 건너뛰기
How to clean and maintain your Vape Mod
필요한 것
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 1 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 1 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 1 단계, 이미지 3개 중 3개
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
  2. How to clean and maintain your Vape Mod: 2 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 2 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 2 단계, 이미지 3개 중 3개
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
  3. How to clean and maintain your Vape Mod: 3 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 3 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 3 단계, 이미지 3개 중 3개
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
  4. How to clean and maintain your Vape Mod: 4 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 4 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 4 단계, 이미지 3개 중 3개
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
  5. How to clean and maintain your Vape Mod: 5 단계, 이미지 2개 중 1개 How to clean and maintain your Vape Mod: 5 단계, 이미지 2개 중 2개
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
  6. How to clean and maintain your Vape Mod: 6 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 6 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 6 단계, 이미지 3개 중 3개
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
  7. How to clean and maintain your Vape Mod: 7 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 7 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 7 단계, 이미지 3개 중 3개
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
  8. How to clean and maintain your Vape Mod: 8 단계, 이미지 3개 중 1개 How to clean and maintain your Vape Mod: 8 단계, 이미지 3개 중 2개 How to clean and maintain your Vape Mod: 8 단계, 이미지 3개 중 3개
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
결론
If your Vape Mod is still not firing, consider getting a new build.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jessie Smith
회원 가입일: 09/29/15
677 평판
안내서 1개를 작성함
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 회원
CPSU-GREEN-F15S14G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 40
전체 시간: 11,289
