이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
This guide is amazing - almost equally because it is so detailed and thorough as because it helped me know exactly how to clean this almost ancient piece of equipment, that's still going strong after what must be 40+ years (in spite of not having been thoroughly, properly cleaned in probably 20!) Acknowledgement to Black & Decker of that era too - let's hear it for American-made products like this one! Thank you for creating this guide!
