주요 콘텐츠로 건너뛰기
How to clean the Avanti 308YWT evaporator pan
  1. How to clean the Avanti 308YWT evaporator pan, How to clean the Avanti 308YWT evaporator pan: 1 단계, 이미지 1/1
    • Before starting, unplug the refrigerator.
  2. How to clean the Avanti 308YWT evaporator pan: 2 단계, 이미지 1/1
    • Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
  3. How to clean the Avanti 308YWT evaporator pan: 3 단계, 이미지 1/1
    • Remove the evaporator tray by simply pulling up and out the tray. make sure that none of the liquid spills.
  4. How to clean the Avanti 308YWT evaporator pan: 4 단계, 이미지 1/2 How to clean the Avanti 308YWT evaporator pan: 4 단계, 이미지 2/2
    • The evaporator tray might have ice build up on it. You can remove this ice by pouring warm water on the tray. After the ice is melted, clean the tray with warm water and soap.
  5. How to clean the Avanti 308YWT evaporator pan: 5 단계, 이미지 1/1
    • Dry and reinsert the tray.
  6. How to clean the Avanti 308YWT evaporator pan: 6 단계, 이미지 1/1
    • Plug the refrigerator back in.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Seye
회원 가입일: 10/11/14
371 평판
안내서 1개 작성함
USF Tampa, Team 1-38, Donnelly Fall 2014 USF Tampa, Team 1-38, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G38
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 43
전체 시간: 3,520
