주요 콘텐츠로 건너뛰기
How to clean the Brother HL-5240 corona wire
  1. How to clean the Brother HL-5240 corona wire, Drum Unit and Toner Cartridge: 1 단계, 이미지 1/1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. How to clean the Brother HL-5240 corona wire: 2 단계, 이미지 1/3 How to clean the Brother HL-5240 corona wire: 2 단계, 이미지 2/3 How to clean the Brother HL-5240 corona wire: 2 단계, 이미지 3/3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: 3 단계, 이미지 1/3 How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: 3 단계, 이미지 2/3 How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: 3 단계, 이미지 3/3
    • Clean the corona wire inside the drum unit by gently sliding the blue tab all the way to left and then back to the far right. Repeat several times.
    • Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nathan Ruiz
회원 가입일: 01/14/10
177 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 회원
CPSU-FORTE-W10S4G14
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 50
전체 시간: 13,190
