소개
If the shutter button of the Canon PowerShot SD780 IS sticks, it could be due to debris or residue inside the camera. This guide will demonstrate how to access the shutter button in order to clean out any unwanted substances.
필요한 것
Before starting, make sure to turn off the camera and remove the battery.
Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
다른 한 분이 해당 안내서를 완성하였습니다.
