이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Before starting, make sure to turn off the camera and remove the battery.
Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
다른 한 분이 해당 안내서를 완성하였습니다.
