주요 콘텐츠로 건너뛰기
How to clean the Epson Stylus Photo 1400
필요한 것
  1. How to clean the Epson Stylus Photo 1400, How to clean the Epson Stylus Photo 1400: 1 단계, 이미지 1개 중 1개
    • Turn off the printer.
    • Remove all paper and CD/DVD tray.
    • Disconnect power from wall socket.
    • Disconnect USB cord from printer.
  2. How to clean the Epson Stylus Photo 1400, Clean the tray feeder.: 2 단계, 이미지 3개 중 1개 How to clean the Epson Stylus Photo 1400, Clean the tray feeder.: 2 단계, 이미지 3개 중 2개 How to clean the Epson Stylus Photo 1400, Clean the tray feeder.: 2 단계, 이미지 3개 중 3개
    • Use a soft brush to clean the sheet feeder.
    • If there are ink spots or dirt on the inside of the printer, use cloth to clean the plastic area shown.
  3. How to clean the Epson Stylus Photo 1400, Clean the inside.: 3 단계, 이미지 3개 중 1개 How to clean the Epson Stylus Photo 1400, Clean the inside.: 3 단계, 이미지 3개 중 2개 How to clean the Epson Stylus Photo 1400, Clean the inside.: 3 단계, 이미지 3개 중 3개
    • Use cloth to clean the plastic parts and metal bar.
    • Try not to touch the roller gears.
  4. How to clean the Epson Stylus Photo 1400, Clean the bottom.: 4 단계, 이미지 3개 중 1개 How to clean the Epson Stylus Photo 1400, Clean the bottom.: 4 단계, 이미지 3개 중 2개 How to clean the Epson Stylus Photo 1400, Clean the bottom.: 4 단계, 이미지 3개 중 3개
    • Wipe off the roller on the bottom with the cloth.
    • Clean off any dust on the plastic tray.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Luis Ruiz
회원 가입일: 09/22/11
43 평판
안내서 1개를 작성함
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 회원
CPSU-REGAN-F11S17G11
4 회원들
안내서 12개를 작성함
댓글 한 개
Thank you! my wonderful printer now prints every line in my Word.docx docs once again. I had no trouble with photo printing, but couldn’t print a letter without losing a few line - and a picture with regular printing with it would have lines streaking through it in blue! Now she works again - my wonderful 1400 workhorse!
Thanks for the tip! My poor girl is OLD, but fantastic.
Pat Dolan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 51
전체 시간: 12,324
