소개
Cleaning the inside of your printer with a Q-tip.
도구
부품
부품은 필요하지 않습니다.
  1. Safely unplug your printer. Pull up on the tab to open the printer window.
    • Safely unplug your printer.
    • Pull up on the tab to open the printer window.
    • Note: If you wish to clean more parts on the inside of your printer follow the guide to remove the top cover. This will give you access to more parts. After removing the top cover follow the next steps.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Apply the Q-tip to the three black, cylindrical rollers shown in the picture. Clean them as much as you see fit. If you notice a lot of dust on other parts of the printer you should clean those as well. For parts with a lot of surface area a damp cloth may be more useful.
    • Apply the Q-tip to the three black, cylindrical rollers shown in the picture. Clean them as much as you see fit.
    • If you notice a lot of dust on other parts of the printer you should clean those as well. For parts with a lot of surface area a damp cloth may be more useful.
    • Note: In the pictures, the top cover of the printer is removed.
  4. Close the printer door (or reattach the top cover if removed), and power on your printer.
    • Close the printer door (or reattach the top cover if removed), and power on your printer.
결승점
Alex Lin
회원 가입일: 2011년 04월 10일
93 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G68
4 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 3,401
