주요 콘텐츠로 건너뛰기
How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers
필요한 것
  1. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Back Panel: 1 단계, 이미지 1/1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: 2 단계, 이미지 1/2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: 2 단계, 이미지 2/2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: 3 단계, 이미지 1/2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: 3 단계, 이미지 2/2
    • Press down on the two plastic hinges to remove the upper portion of printer.
    The two plastic hinges WON’T PRESS DOWN in order to release them from their housing and lift away the top. I am even resorting to wedging a very thin flat headed screwdriver in on top of the hinge to see if this makes a difference but nothing will budge.
    Maeshowie - 답글
    Further to my first comment, the hinge in the diagram looks slightly different to the ones on the rear of my printer in that the diagram ones look as if they WILL press down, finger force, to release the top.
    I’ve given up and am putting it all back together again. Must now look to see if I can send this printer to someone who knows what they are doing.
    Maeshowie - 답글
    Third and last comment. I tried one last time to release the top, pressed down on the hinge - and it snapped off. This one to the dump and online to buy a new one.
    Maeshowie - 답글
  4. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Unplug Speaker Wire: 4 단계, 이미지 1/1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: 5 단계, 이미지 1/2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: 5 단계, 이미지 2/2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray - cont.: 6 단계, 이미지 1/1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
    It would be easer to do steps 7 & 8 before step 6.
    Richard Scott - 답글
  7. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 7 단계, 이미지 1/1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 8 단계, 이미지 1/1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Detaching the Scanner Tray: 9 단계, 이미지 1/1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
    But how do you get to the inside of scaner?
    R S V P Urgent
    Paul D
    pauldaley08 - 답글
    As from N0 9 Done thus far but can not get inside scanner itself. Have removed screw Back L H Side, but do not wish to brake in — somthing is holding (more screws?)
    Yrs Paul D
    pauldaley08@hotmail.com
    pauldaley08 - 답글
  10. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 10 단계, 이미지 1/1
    • Using the T10 Torx Security Bit Screwdriver, remove the four black screws holding the printer carriage cover in place.
  11. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 11 단계, 이미지 1/1
    • Depress plastic tabs to release the cover from the sides.
    • There is nothing holding the left side panel in place, so pull it away from the printer body.
  12. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 12 단계, 이미지 1/1
    • Turn the smallest white plastic gear on the left side of the printer to rotate feed rollers.
  13. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Clean Rollers: 13 단계, 이미지 1/1
    • While rotating the feed rollers, clean them with purified or distilled water and a lint-free cloth.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Cody Long
회원 가입일: 04/12/11
153 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 회원
CPSU-MANESS-S11S12G31
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
Nice instructions, but there's nothing here about the video card readers on the right front. Can't get the right-side panel off. Otherwise, the instructions are well displayed.
Gayle Bryan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 11,991
