소개
Your printer is bound to collect dust over time, and a lot of this dust rests on the underside of your scanner glass. This affects the quality of your scans.
Cleaning the scanner glass is fairly simple: the scanner tray must be removed prior to removing the scanner glass.
Proper cleaning of your scanner glass will require alcohol and a lint-free cloth.
필요한 것
Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
Turn the scanner glass over so its underside is facing upward.
Place the scanner glass on a clean surface.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 8개
Great! I followed the instructions already a couple of years ago, and found it now again! Great help! Thank you!
Worked great, but it did take more than 2-3 minutes!
clintsmith - 답글
