주요 콘텐츠로 건너뛰기
How to clean the HP Photosmart 2575 All-in-One's scanner glass
필요한 것
  1. How to clean the HP Photosmart 2575 All-in-One's scanner glass, Control Panel Faceplate: 1 단계, 이미지 1개 중 1개
    • Remove the control panel faceplate by lifting up at the notch.
  2. How to clean the HP Photosmart 2575 All-in-One's scanner glass, Detach control panel (not wires): 2 단계, 이미지 1개 중 1개
    • Unscrew one T10 screw near the bottom of the control panel
    • Lift the control panel up at the bottom, around 5 mm above the machine and pull the panel towards the front of the machine.
    • Now you have access to the screws below the control panel.
    • Note: I haven't been able to disconnect the flat flexible cable and the JST connector from the PCB.
  3. How to clean the HP Photosmart 2575 All-in-One's scanner glass, How to clean the HP Photosmart 2575 All-in-One's scanner glass: 3 단계, 이미지 2개 중 1개 How to clean the HP Photosmart 2575 All-in-One's scanner glass, How to clean the HP Photosmart 2575 All-in-One's scanner glass: 3 단계, 이미지 2개 중 2개
    • Remove seven T10 screws.
    • Unhook the two larger clips on the back side. Do not unhook the smaller clip as it will detach the glass pane.
    • Begin lifting up the panel with the scanner glass by lifting up the two large clips. Be careful as the glass pane is not secured very well.
    • Wipe dust from the underside and the upper side of the glass pane using a microfiber cloth.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Axel Karjalainen
회원 가입일: 11/14/25
2 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 20
