주요 콘텐츠로 건너뛰기
How to clean the Magnavox MWD200F optical lens
필요한 것
  1. How to clean the Magnavox MWD200F optical lens, Faceplate: 1 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean the Magnavox MWD200F optical lens: 2 단계, 이미지 1/1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean the Magnavox MWD200F optical lens: 3 단계, 이미지 1/1
    • Unclip the three latches on the bottom of the device.
  4. How to clean the Magnavox MWD200F optical lens: 4 단계, 이미지 1/1
    • Pull the faceplate off.
  5. How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: 5 단계, 이미지 1/3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: 5 단계, 이미지 2/3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: 5 단계, 이미지 3/3
    • Locate the optic lens in the middle of the disc drive. Dip a cotton swab in rubbing alcohol and use it to lightly wipe the lens. After the lens is clear of dust and debris, wait a few minutes to let it air dry.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 09/08/11
112 평판
안내서 1개 작성함
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 회원
UMAINE-DIAZ-F11S1G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,378
