주요 콘텐츠로 건너뛰기
How to clean the Pentax PZ-10 gears
필요한 것
  1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: 1 단계, 이미지 1/2 How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: 1 단계, 이미지 2/2
    • Place the lens face up to locate the bottom cover.
    • Remove the two 7mm screws using a J0 screwdriver.
    • Remove the six 4.3 mm screws using a J0 screwdriver.
  2. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover: 2 단계, 이미지 1/1
    • After the screws are removed, the bottom cover should easily pry off.
  3. How to clean the Pentax PZ-10 gears, Accessing Gears: 3 단계, 이미지 1/2 How to clean the Pentax PZ-10 gears, Accessing Gears: 3 단계, 이미지 2/2
    • Using a J0 screwdriver, remove the 4mm screw holding the metal plate to expose the gears.
  4. How to clean the Pentax PZ-10 gears, Removing Gear Housing Plate: 4 단계, 이미지 1/1
    • Using a pair of tweezers, gently remove the metal plate covering the gears.
    • Part of the plate's tab fits into a socket. Try to pivot around it when removing the plate to prevent bending the plate.
    • Be careful with the gears because some may be loose.
  5. How to clean the Pentax PZ-10 gears, Cleaning the Gears: 5 단계, 이미지 1/2 How to clean the Pentax PZ-10 gears, Cleaning the Gears: 5 단계, 이미지 2/2
    • Use tweezers to rotate gears or remove any large particles obstructing their rotation.
    • Smaller particles can be cleared using a microfiber cloth only. Other fabrics may leave residual fibers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryan Sugiarto
회원 가입일: 04/20/15
252 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 855
