주요 콘텐츠로 건너뛰기
How to clean the Samsung SGH-E317 keypad
필요한 것
  1. How to clean the Samsung SGH-E317 keypad, Battery: 1 단계, 이미지 1/1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: 2 단계, 이미지 1/1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: 3 단계, 이미지 1/1
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: 4 단계, 이미지 1/1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: 5 단계, 이미지 1/1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: 6 단계, 이미지 1/1
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: 7 단계, 이미지 1/2 How to clean the Samsung SGH-E317 keypad: 7 단계, 이미지 2/2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: 8 단계, 이미지 1/2 How to clean the Samsung SGH-E317 keypad: 8 단계, 이미지 2/2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: 9 단계, 이미지 1/2 How to clean the Samsung SGH-E317 keypad: 9 단계, 이미지 2/2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: 10 단계, 이미지 1/1
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: 11 단계, 이미지 1/1
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: 12 단계, 이미지 1/2 How to clean the Samsung SGH-E317 keypad: 12 단계, 이미지 2/2
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joe Cavaletto
회원 가입일: 01/30/11
101 평판
안내서 1개 작성함
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 회원
CPSU-MANESS-W11S11G23
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 947
