주요 콘텐츠로 건너뛰기
How to clean the Sega Genesis game port
필요한 것
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: 1 단계, 이미지 1/1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: 2 단계, 이미지 1/1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: 3 단계, 이미지 1/1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: 4 단계, 이미지 1/1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
결승점
다른 11명이 해당 안내서를 완성하였습니다.
Erik Bjornstrom
회원 가입일: 10/04/10
829 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 회원
CPSU-REGAN-F10S3G29
4 회원들
안내서 14개 작성하였습니다
댓글 4개
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - 답글
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - 답글
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - 답글
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 171
전체 시간: 36,130
