주요 콘텐츠로 건너뛰기
How to clean the Sega Genesis game port
필요한 것
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: 1 단계, 이미지 1개 중 1개
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: 2 단계, 이미지 1개 중 1개
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: 3 단계, 이미지 1개 중 1개
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: 4 단계, 이미지 1개 중 1개
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
결승점
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Erik Bjornstrom
회원 가입일: 10/04/10
852 평판
안내서 3개를 작성함
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 회원
CPSU-REGAN-F10S3G29
4 회원들
안내서 14개를 작성함
5가이드 댓글
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - 답글
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - 답글
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - 답글
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - 답글
I tried alcohol and toothbrush, q-tips, and looked over the board for circuit problems. I was still getting a black screen for every game i tried. But this worked perfectly. I'm shocked. My contacts were already shiny clean but they needed light sandpaper apparently.
colinplank - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 92
전체 시간: 38,506
