주요 콘텐츠로 건너뛰기
How to clean the Shure SM58 XLR connector
필요한 것
  1. How to clean the Shure SM58 XLR connector, XLR Microphone Connector Disassembly: 1 단계, 이미지 1개 중 1개
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. How to clean the Shure SM58 XLR connector: 2 단계, 이미지 1개 중 1개
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. How to clean the Shure SM58 XLR connector, How to clean the Shure SM58 XLR connector: 3 단계, 이미지 1개 중 1개
    • Using a detailing brush, gently brush the pins and inside walls of the microphone.
  4. How to clean the Shure SM58 XLR connector: 4 단계, 이미지 1개 중 1개
    • Do not solder microphone parts without prior soldering experience.
    • Only attempt this step if you have previously soldered inside the microphone. If the pins on the inside of the connector have excess solder on them, take a soldering iron and melt of excess solder.
  5. How to clean the Shure SM58 XLR connector: 5 단계, 이미지 1개 중 1개
결론
To reassemble your device, follow these instructions in reverse order. After cleaning the connector, your microphone is ready to connect to XLR cables.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
811 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 4,416
