주요 콘텐츠로 건너뛰기
How to clean the Shure SM58
필요한 것
  1. How to clean the Shure SM58, Collar: 1 단계, 이미지 3개 중 1개 How to clean the Shure SM58, Collar: 1 단계, 이미지 3개 중 2개 How to clean the Shure SM58, Collar: 1 단계, 이미지 3개 중 3개
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. How to clean the Shure SM58, How to clean the Shure SM58: 2 단계, 이미지 1개 중 1개
    • Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
    • Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
  3. How to clean the Shure SM58: 3 단계, 이미지 1개 중 1개
    • Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
    • If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
결론
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
811 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 33개를 작성함
2가이드 댓글
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Mike gallagher - 답글
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
karl_ivers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 71
전체 시간: 11,593
