주요 콘텐츠로 건너뛰기
How to clean your Panasonic SA-HT810V VCR heads
필요한 것
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 1 단계, 이미지 1/3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 1 단계, 이미지 2/3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 1 단계, 이미지 3/3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: 2 단계, 이미지 1/2 How to clean your Panasonic SA-HT810V VCR heads: 2 단계, 이미지 2/2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: 3 단계, 이미지 1/1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: 4 단계, 이미지 1/3 How to clean your Panasonic SA-HT810V VCR heads: 4 단계, 이미지 2/3 How to clean your Panasonic SA-HT810V VCR heads: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathan Cheadle
회원 가입일: 04/15/10
161 평판
안내서 7개 작성하였습니다
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 30
전체 시간: 2,698
