소개
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
부품
부품은 필요하지 않습니다.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. This is the air filter assembly
    • This is the air filter assembly
  5. Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  6. Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  7. Reassemble the air filter assembly and slide the particle bin back into place
    • Reassemble the air filter assembly and slide the particle bin back into place
결론
다른 3명이 해당 안내서를 완성하였습니다.
Scott Leonard
회원 가입일: 2010년 10월 05일
439 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 회원
CPSU-MANESS-F10S20G6
2 회원들
안내서 3개 작성하였습니다
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - 답글
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 4,711
