주요 콘텐츠로 건너뛰기
How to clean your Roomba 4100's air filter.
필요한 것
  1. How to clean your Roomba 4100's air filter., How to clean your Roomba 4100's air filter.: 1 단계, 이미지 1/1
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. How to clean your Roomba 4100's air filter.: 2 단계, 이미지 1/1
    • Slide out yellow bar on particle bin to access filter
  3. How to clean your Roomba 4100's air filter.: 3 단계, 이미지 1/1
    • This is the air filter assembly
  4. How to clean your Roomba 4100's air filter.: 4 단계, 이미지 1/1
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  5. How to clean your Roomba 4100's air filter.: 5 단계, 이미지 1/1
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  6. How to clean your Roomba 4100's air filter.: 6 단계, 이미지 1/1
    • Reassemble the air filter assembly and slide the particle bin back into place
결론
다른 3명이 해당 안내서를 완성하였습니다.
Scott Leonard
회원 가입일: 10/05/10
445 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 회원
CPSU-MANESS-F10S20G6
2 회원들
안내서 3개 작성하였습니다
댓글 한 개
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 5,211
