주요 콘텐츠로 건너뛰기
How to clean/replace buttons on the Skytex SP728
필요한 것
  1. How to clean/replace buttons on the Skytex SP728, Case: 1 단계, 이미지 1/1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: 2 단계, 이미지 1/1
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: 3 단계, 이미지 1/1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: 4 단계, 이미지 1/1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: 5 단계, 이미지 1/1
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: 6 단계, 이미지 1/1
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Nelson
회원 가입일: 01/21/15
213 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 회원
USFT-BROWN-W15S5G1
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 124
