주요 콘텐츠로 건너뛰기
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: 1 단계, 이미지 1/2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: 1 단계, 이미지 2/2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: 2 단계, 이미지 1/2 How to clear Lexmark Intuition S505 paper jam: 2 단계, 이미지 2/2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: 3 단계, 이미지 1/1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: 4 단계, 이미지 1/1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
결론
Once the paper obstruction is removed, your printer should print smoothly without any problems.
다른 2명이 해당 안내서를 완성하였습니다.
Omar
회원 가입일: 01/23/13
111 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 회원
CPSU-REGAN-W13S18G38
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,653
