주요 콘텐츠로 건너뛰기
How to clear a Epson Stylus Photo 820 paper jam
  1. How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: 1 단계, 이미지 1/2 How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: 1 단계, 이미지 2/2
    • If a paper jam is detected, the middle button will display a red light.
    • Press the red button. This will cause the printer to try to automatically correct the issue.
    • If this works, proceed to step 4. Otherwise, proceed to step 2.
  2. How to clear a Epson Stylus Photo 820 paper jam: 2 단계, 이미지 1/2 How to clear a Epson Stylus Photo 820 paper jam: 2 단계, 이미지 2/2
    • The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
    • Pull the paper slowly, and as straight as possible.
    • If this does not work, proceed to step 3.
  3. How to clear a Epson Stylus Photo 820 paper jam: 3 단계, 이미지 1/2 How to clear a Epson Stylus Photo 820 paper jam: 3 단계, 이미지 2/2
    • Assuming the paper will not come out of the top, assess the paper jam.
    • If the print cartridge is in the way, gently push it to the side.
    • Try to get the full edge of the paper above the metal grating.
    • Gently pull the paper out the of the open hatch.
  4. How to clear a Epson Stylus Photo 820 paper jam: 4 단계, 이미지 1/2 How to clear a Epson Stylus Photo 820 paper jam: 4 단계, 이미지 2/2
    • If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
    • If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • This may cause another sheet of paper to be pulled through. Do not be alarmed.
    • This should cause the red light to go out.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
dante gagliardi
회원 가입일: 04/13/11
45 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G68
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 3,260
