주요 콘텐츠로 건너뛰기
How to clone a Hard Drive or a Solid State Drive on a Mac
필요한 것
  1. How to clone a Hard Drive or a Solid State Drive on a Mac, Downloading Carbon Copy Cloner: 1 단계, 이미지 1/1
    • Download Carbon Copy Cloner from the Bombich Software Website.
    • Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
    • You can download it here.
    • I used CCC 5 for this process and if the user interface changes in the future I will promptly update the guide.
    Aaron, Please post the version info for the app you used.
    Dan - 답글
    @danj Edited. Good idea, thanks!
    [deleted] - 답글
  2. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Source Disk: 2 단계, 이미지 1/1
    • Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
    • Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
  3. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Target Disk: 3 단계, 이미지 1/1
    • Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
  4. How to clone a Hard Drive or a Solid State Drive on a Mac, Cloning: 4 단계, 이미지 1/1
    • Lastly, click Clone.
    • Enter your administrator Username
    • Enter your administrator Password
    • Then finally, click OK
    • This process can take up to 4+ hours depending on your disk size, so have some patience!
결론
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
다른 25명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 08/28/18
26,409 평판
안내서 21개 작성하였습니다
댓글 9개
I have used CCC for years and years. It is an excellent program!
When upgrading MAC OS to a new version, I always clone a drive before starting the upgrade.
Mal - 답글
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
Fran Werttt - 답글
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan -
I have tried cloning my 2012 Mac book pro with a vector ssd sata111, my Mac does not see the disk when I connect with usb or caddy, this is getting frustrating anyone has the same problem where you mac not seeing the ssd drive
thank you
Peter
Peter - 답글
What about using Restore on Disk Utility read on web that this in itself a cloning method don’t have to go for 3rd party apps
GBish - 답글
Unfortunately that method has some glitches for some users. (Like myself) see error OSStatus error 22
Diana Fred -
I’ve used Restore from Disk Utility and it worked very well. First boot with Cmd-R held down. Make sure to Unmount internal and external drives, then select Restore blank drive from old one.
Friedemann Brauer -
Thanks for writing the guide! Will this clone be ready to once I insert the clone drive in? Should I make a boot disk?
Peter Innes - 답글
I am trying to bypass the 6 digit pin on my macbook pro. I purchased it as an open box at Best Buy and after a break in at my home, marked the computer lost/stolen. Well I got it back but after months of it being gone, I forgot the pin I set. Because I am not the original owner, Apple will not help me even though I have proof of purchase. This is so frustrating and I need someone to help me.
Catherine Daugherty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 49
7일 전: 323
30일 전: 1,438
전체 시간: 30,463
