이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Download Carbon Copy Cloner from the Bombich Software Website.
Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
Lastly, click Clone.
Enter your administrator Username
Enter your administrator Password
Then finally, click OK
다른 25명이 해당 안내서를 완성하였습니다.
댓글 9개
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan -
