주요 콘텐츠로 건너뛰기
How to configure "Client Mode" on TP-Link TL-WR802N
  1. How to configure "Client Mode" on TP-Link TL-WR802N, How to configure "Client Mode" on TP-Link TL-WR802N: 1 단계, 이미지 1개 중 1개
    • Reset router to a factory (reset button for 5-10 seconds).
  2. How to configure "Client Mode" on TP-Link TL-WR802N: 2 단계, 이미지 1개 중 1개
    • Use PC to connect through WiFi to TP-LINK_xx SSID.
  3. How to configure "Client Mode" on TP-Link TL-WR802N: 3 단계, 이미지 1개 중 1개
    • In the browser open a page with IP address 192.169.0.1 (usually default gateway), and login using admin/admin
  4. How to configure "Client Mode" on TP-Link TL-WR802N: 4 단계, 이미지 3개 중 1개 How to configure "Client Mode" on TP-Link TL-WR802N: 4 단계, 이미지 3개 중 2개 How to configure "Client Mode" on TP-Link TL-WR802N: 4 단계, 이미지 3개 중 3개
    • Go through setup steps: [Next] -> select “Client” mode -> [Next]
    • Select AP with SSID you want to use it with (if does not appear, refresh it). Then hit [Next]
    • Confirm SSID, specify security settings, shared key if needed, etc. -> [Next]
  5. How to configure "Client Mode" on TP-Link TL-WR802N: 5 단계, 이미지 2개 중 1개 How to configure "Client Mode" on TP-Link TL-WR802N: 5 단계, 이미지 2개 중 2개
    • Select type: “Static IP”
    • Configure static IP address within your wireless network (preferably outside your DHCP scope)
    • Configure subnet mask as needed
    • Make sure “DHCP Server” is “Enabled”
    • [Next] -> Reboot
  6. How to configure "Client Mode" on TP-Link TL-WR802N: 6 단계, 이미지 1개 중 1개
    • After this you need to connect another PC to the Ethernet port. It should get IP address from your wireless network, but it will be unable to communicate to the rest of the network, only to the router.
    • *** Generally that’s where “User Manual” stops...
  7. How to configure "Client Mode" on TP-Link TL-WR802N: 7 단계, 이미지 1개 중 1개
    • Go to the browser and connect to IP address of the router (which you just configured above). Login with admin/admin
  8. How to configure "Client Mode" on TP-Link TL-WR802N: 8 단계, 이미지 2개 중 1개 How to configure "Client Mode" on TP-Link TL-WR802N: 8 단계, 이미지 2개 중 2개
    • Go to “Network” section, and configure “Gateway” as the “default gateway” of your WiFi network (after wizard it comes as a TP-Link router address)
    • Hit “Save” and router will reboot.
    • After reboot you will be able to access router from either LAN or locally connected PC (local connection may be faster and more reliable).
  9. How to configure "Client Mode" on TP-Link TL-WR802N: 9 단계, 이미지 1개 중 1개
    • Login again (if needed), and now go to DHCP section
    • DHCP Server: Enabled
    • Start IP: <start IP address> End IP: <end IP address>
    • Gateway: <IP address of WiFi network gateway>
    • Domain: <your domain>
    • DNS: <your DNS servers>
  10. How to configure "Client Mode" on TP-Link TL-WR802N: 10 단계, 이미지 1개 중 1개
    • After this – disconnect Ethernet, power off router, then reboot PC (it may retain default route of the TP-Link router, better reboot it), and then connect Ethernet.
    • You will be connected to the WiFi network, repeat it a couple times to make sure the process is repeatable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Headset Adapter Co
회원 가입일: 03/15/17
259 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 146
전체 시간: 12,649
