필요한 것
Go to https://www.samsung.com/levant/support/k... , download and install the program.
From the main menu, go to Settings,
Then select the 8th option "PC connections",
Finally, select the option "Samsung Kies".
While the phone is connecting, you will see this screen.
Lastly, you have finally connected your phone successfully to your PC! Explore your options via Samsung Kies!
거의 끝나갑니다!
Close to program and disconnect your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
