주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to convert a generic Chromebook to Linux OS
필요한 것
  1. How to convert a generic Chromebook to Linux OS, How to convert a generic Chromebook to Linux OS: 1 단계, 이미지 2개 중 1개 How to convert a generic Chromebook to Linux OS, How to convert a generic Chromebook to Linux OS: 1 단계, 이미지 2개 중 2개
    • You will need a couple of decent sized USB sticks. I used 16gb sandisk cruzer sticks. One for your desired live linux image and one for taking a backup of your original chromeos supporting image. The second one is optional since you only need that if you ever want to go back to your chromeos image.
    • I did it just in case I bricked my laptop. Turned out to be unnecessary since the script worked perfectly. You can probably skip taking the chromeos flash backup since it probably won't be needed for yours either.
    • Download amd64 lubuntu LTS image or whatever flavor you desire of linux. Burn it on one of your USB sticks with software suitable for creating bootable USB sticks. Download: http://cdimage.ubuntu.com/lubuntu/releas...
    • Note that you may use a second computer to perform the above step. I was able to do it with my crouton chroot on my existing Pavilion chromebook. I use and recommend Etcher software for this step: Linux - Mac - Windows creating bootable images on USB keys - SD cards the easy way. or...
    • You can burn to any USB device with this technique: you can try with the "chromebook recovery utility" from the web store. It basically does a dd of any image with a .bin extension, rename your downloaded linux iso to add the .bin extension, then on the tool choose "use a local image" by clicking the gear icon at the top right.
    • You are now ready to "unscroogle" your chromebook. Remember those silly ads? I actually loved my chromebook for five very productive years. If it was not unsupported, I would continue to use as is too.
    댓글 쓰기
  2. How to convert a generic Chromebook to Linux OS, Turn off write protect of system on chromebook hardware: 2 단계, 이미지 1개 중 1개
    댓글 쓰기
  3. How to convert a generic Chromebook to Linux OS, Important information for RW_LEGACY option.: 3 단계, 이미지 1개 중 1개
    • Some chromebooks can support the RW_LEGACY option but many older ones can't. If yours can it is possible to dual boot the machine and retain your chromeOS functionality and have a discretely bootable linux system as well.
    • You most likely will need more storage to support this kind of setup. Since this is advanced usage, I won't cover that sort of thing here. Since google in their wisdom will stop supporting your hardware/software after only five years you probably don't care about dual booting anyway do you?
    댓글 쓰기
  4. How to convert a generic Chromebook to Linux OS, Get ready!: 4 단계, 이미지 3개 중 1개 How to convert a generic Chromebook to Linux OS, Get ready!: 4 단계, 이미지 3개 중 2개 How to convert a generic Chromebook to Linux OS, Get ready!: 4 단계, 이미지 3개 중 3개
    • Press [ Ctrl ] [ Alt ] [ T ] to get to the crosh shell prompt on the chromebook (See first image). Note: these first 3 shell images were captured via cloudready which is a chromeos workalike not an actual chromebook but are identical for our purposes here.
    • Use the "shell" command to get to the shell prompt. Just type "shell" into the prompt and press enter (see second shell screen image).
    • Type the following (or cut and paste into a single command line... see third shell screen image). I include the full command in the next bullet point...
    • cd; curl -LO https://mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
    • Press enter on above command line when you are ready to start converting your chromebook to a fully functional general purpose personal computer.
    댓글 쓰기
  5. How to convert a generic Chromebook to Linux OS, All chromebooks go to heaven!: 5 단계, 이미지 1개 중 1개
    • You should get that menu (see graphic) with appropriate device data for your particular Chromebook. Select option 3 to flash a full UEFI capable rom onto your system. Note this is the end of your chromebook effectively once you pass the clearly identified "point of no return".
    • Note: Some chromebook architectures are unsupported (notably ARM cpu systems). You may get a error message if your system is unsupported.
    • You can either perform the chromeos rom backup or not as the option presents itself (your choice). You will need that extra USB stick if you choose to backup the original rom. Do you feel lucky punk? Sorry :D
    • Once it is finished it will prompt you to power off and restart the device. At that point you can insert your new linux boot/install USB stick. From there you simply install like you would on any typical laptop.
    • I opted to go the full UEFI route on mine but it is optional. Follow the instructions under the FAQs (https://mrchromebox.tech/#faq) The fifth question there is answered with how to proceed to setup your UEFI boot option files correctly.
    댓글 쓰기
  6. How to convert a generic Chromebook to Linux OS, Wrap up... or... The king is dead long live the king!: 6 단계, 이미지 1개 중 1개
    • I have installed cairo-dock and now my hardware is off the leash. I now have the poor man's friend... the free-open-source- software macintosh work-alike.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
tcagle53
회원 가입일: 06/18/14
8,790 평판
안내서 11개를 작성함
Chromebook Cowboys Chromebook Cowboys 회원
Community
4 회원들
안내서 50개를 작성함
14가이드 댓글
Thank you very much for the detailed information. I have successfully converted my ASUS C302C chromebook to Linux laptop.
Yu-Ten Lee - 답글 공유
A better and safer way to install Linux on Chromebooks exists :) https://cb-linux.github.io/breath/
Cameron - 답글 공유
Thanks for the useful input Cameron. I added a follow up note to the heading here. Now I am going shopping for a more modern used chromebook.
tcagle53 - 답글 공유
hello, thank you for sharing
i want to ask for lenovo chromebook slim 3, can it install linux?, cause when i reboot and start to mode developer not found properly
Ahmad Rimba - 답글 공유
Did you read "Note2" in the above introduction? If not and if your device is supported by "breath" that may be a viable approach. It is a fairly complicated process that I have not tried so beware if it is out of your comfort zone.
tcagle53 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 206
지난 30일: 1,076
전체 시간: 160,766
