주요 콘텐츠로 건너뛰기
How to cool down your wificard
필요한 것
동영상 개요
  1. How to cool down your wificard, How to cool down your wificard: 1 단계, 이미지 1개 중 1개
    • Carefully take off the top
  2. How to cool down your wificard: 2 단계, 이미지 1개 중 1개
    • unscrew the keyboard
  3. How to cool down your wificard: 3 단계, 이미지 1개 중 1개
    • Pull the keyboard out
  4. How to cool down your wificard: 4 단계, 이미지 1개 중 1개
    • Carefully unplug the Aux and Main off the WiFi card
  5. How to cool down your wificard: 5 단계, 이미지 1개 중 1개
    • unscrew it
  6. How to cool down your wificard: 6 단계, 이미지 1개 중 1개
    • Add a lot of NON CONDUCTIVE thermal compound
  7. How to cool down your wificard: 7 단계, 이미지 1개 중 1개
    • screw the card back on
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
G 2
회원 가입일: 06/05/17
191 평판
안내서 1개를 작성함
2가이드 댓글
The thermal paste is intended to *help transfer heat from one surface to another. What is shown here is sticking the backside of the WiFi card to a plastic film on the motherboard.. there is no way for the heat to dissipate on that spot. Further more the heat is not even coming off the backside of the WiFi card.. This guide will NOT help cool down your chip. Further more I took apart my L300 07N and it has an Atheros based chip not a “Dell” Intel model as seen in the pictures here.. and.. the wires on my chip were connected the opposite of the pictures here. So maybe he has a different model than me? and it probably won’t make much difference which way the antennaes wires are connected anyway. I was looking at this for an upgrade.. i put in the Intel 4965AGN MM1 Full size PCIe card and it works great, it had 3 pins and i used pins 1 & 3 (Grey on 1 and black on 3) all 3 are antenna connections on the Intel. My 5G speed tests were fast and the radio switch still works and got no weird blinking light issues.
xpmule - 답글
look mate its actually transferring heat from the wifi card to the other side of the motherboard which is covered by the two heat pipes which transfer and dissipate the heat. Please come with proof next time instead of accusing me
G 2 -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 16
전체 시간: 847
