주요 콘텐츠로 건너뛰기
How to create a Chrome OS Flex USB installer
필요한 것
  1. How to create a Chrome OS Flex USB installer, Install the Chromebook Recovery Utility: 1 단계, 이미지 2개 중 1개 How to create a Chrome OS Flex USB installer, Install the Chromebook Recovery Utility: 1 단계, 이미지 2개 중 2개
    • Open Google Chrome and navigate to the Chrome Web Store
    • Add Google's Chromebook Recovery Utility to Chrome by clicking Add to Chrome
    • When prompted, click Add extension
    • At the top right of Chrome's browser window, click More Tools and then Extensions
    • Next to the newly installed Chromebook Recovery Utility toggle the switch to on.
  2. How to create a Chrome OS Flex USB installer, Build your USB installer: 3 단계, 이미지 3개 중 1개 How to create a Chrome OS Flex USB installer, Build your USB installer: 3 단계, 이미지 3개 중 2개 How to create a Chrome OS Flex USB installer, Build your USB installer: 3 단계, 이미지 3개 중 3개
    • From Chrome, launch the Chrome Recovery Utility extension.
    • Click Get started
    • Click Select a model from a list
    • For the Select a manufacturer option, find and choose Google Chrome OS Flex.
    • For the Select a product option, find and choose Chrome OS Flex (Developer-Unstable).
  3. How to create a Chrome OS Flex USB installer, Building your USB Installer (Continued): 4 단계, 이미지 1개 중 1개
    • Click on Continue, and choose your USB device from the dropdown menu.
    • Click Continue and once prompted click Create now.
    • You can remove your recovery USB once the finish message is displayed.
결론
Now that you have your USB Installer, you can install ChromeOS Flex onto any computer from 2010 or later. To install Flex onto a computer, boot your USB drive from the device's BIOS and follow the onscreen instructions.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
44,583 평판
안내서 51개를 작성함
iFanatics iFanatics 회원
Community
63 회원들
안내서 219개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 41
지난 30일: 175
전체 시간: 11,738
