주요 콘텐츠로 건너뛰기
How to create a ChromeOS Recovery USB Drive
필요한 것
    • In order to make your recovery device, you will need the following items.
    • 1 x USB Drive or SD Card (8 GB is the minimum)
    • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
    • 1 x computer running the Google Chrome Browser, or Chrome OS.
  1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 2 단계, 이미지 2개 중 1개 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 2 단계, 이미지 2개 중 2개
    • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
    • Add the utility to Chrome and launch it. You will be greeted with this page.
  2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: 3 단계, 이미지 1개 중 1개
    • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
    • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
  3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: 4 단계, 이미지 1개 중 1개
    • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
    • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
  4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: 5 단계, 이미지 1개 중 1개
    • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
    • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
결론
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
다른 88명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
44,583 평판
안내서 51개를 작성함
iFanatics iFanatics 회원
Community
63 회원들
안내서 219개를 작성함
15가이드 댓글
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - 답글
I'm glad to hear that this guide helped you out!
Jacob Mehnert -
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - 답글
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Jacob Mehnert -
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - 답글
댓글 쓰기
조회 통계:
지난 24시간: 46
지난 7일: 336
지난 30일: 1,360
전체 시간: 50,883
