주요 콘텐츠로 건너뛰기
How to create a Tails Live USB
필요한 것
  1. How to create a Tails Live USB, Download Tails OS: 1 단계, 이미지 2개 중 1개 How to create a Tails Live USB, Download Tails OS: 1 단계, 이미지 2개 중 2개
  2. How to create a Tails Live USB, Download and install BalenaEtcher: 2 단계, 이미지 1개 중 1개
    • Insert the USB flash drive into an available USB port on your computer and launch Etcher.
    • In Etcher, click "Flash from file" and select the Tails ISO image you downloaded earlier.
    • Select the USB flash drive as the target device.
    • Double-check to ensure you have selected the correct drive, as the process will erase all data on the selected drive.
    • Click "Flash!" to start the process. Etcher will copy the Tails OS to the USB drive.
    • Once the flashing process is complete, safely eject the USB drive from your computer.
    • Etcher should do this automatically, however it is still good practice to check that the drive was ejected properly.
    • Insert the Tails live USB into the computer you want to use.
    • Restart the computer and enter the boot menu by pressing the appropriate key during startup (usually F2, F12, or Delete).
    • Select the USB drive as the boot device from the boot menu.
    • Tails will start, and you'll be presented with the Tails Greeter screen.
    • Follow the on-screen instructions to configure language, keyboard, and other settings.
    • Once completed you will be able to use your computer in a secure and private live environment. Your online activities are routed through the Tor network for anonymity.
결론
Creating a Tails live USB using this iFixit guide provides you with a secure and private way to use Tails OS on any computer without leaving traces. Remember to always use Tails responsibly and respect the privacy and security it offers.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
44,284 평판
안내서 51개를 작성함
iFanatics iFanatics 회원
Community
63 회원들
안내서 218개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 33
지난 7일: 286
지난 30일: 1,322
전체 시간: 19,157
