주요 콘텐츠로 건너뛰기
How to deoxidize Onkyo TX-800 circuits
필요한 것
  1. How to deoxidize Onkyo TX-800 circuits, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 1/3 How to deoxidize Onkyo TX-800 circuits, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 2/3 How to deoxidize Onkyo TX-800 circuits, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 3/3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. How to deoxidize Onkyo TX-800 circuits: 2 단계, 이미지 1/2 How to deoxidize Onkyo TX-800 circuits: 2 단계, 이미지 2/2
    • Remove the top screw on the back panel.
  3. How to deoxidize Onkyo TX-800 circuits: 3 단계, 이미지 1/2 How to deoxidize Onkyo TX-800 circuits: 3 단계, 이미지 2/2
    • Slide off the case to expose the internal components of the receiver.
  4. How to deoxidize Onkyo TX-800 circuits, How to deoxidize Onkyo TX-800 circuits: 4 단계, 이미지 1/1
    • Carefully wipe the circuit board and its components to remove any dust.
    • Failing to remove any dust before applying DeoxIT may cause the dust to get trapped on the components, increasing the risk of overheating.
  5. How to deoxidize Onkyo TX-800 circuits: 5 단계, 이미지 1/1
    • Lightly spray the circuit board with DeoxIT.
    • Take care to evenly coat the circuit board with DeoxIT. Excess liquid will dry slowly. If power is reapplied before it has completely dried, it can cause short-circuits and damage to the device.
  6. How to deoxidize Onkyo TX-800 circuits: 6 단계, 이미지 1/2 How to deoxidize Onkyo TX-800 circuits: 6 단계, 이미지 2/2
    • Lightly spray the input and output connectors with DeoxIT on the inside of the back panel.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Kevin Barton
회원 가입일: 04/13/10
131 평판
안내서 1개 작성함
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G92
4 회원들
안내서 7개 작성하였습니다
댓글 2개
As an electronic repair technician I would never advise spraying deoxit on a circuit board or removing dust with a papertowel. May I suggest using a can of compressed air to remove any dust inside the unit and focusing the use of contact cleaner on potentiometers, input/output jacks, sockets/plugs etc. Cleaning the top of the circuit board will do little to nothing to improve the performance or sound of your amplifier as you will simply be cleaning the top side of components that are physically soldered to pads on the other side of the PCB.
Muham - 답글
A soft long bristle brush
Michel Joseph Cardin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 20
전체 시간: 5,972
