소개
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
  1. Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take something sharp and make hole where the chip was.
    댓글 쓰기
  2. Use a pair of scissors and cut the card into thin strips.
    • Use a pair of scissors and cut the card into thin strips.
    • See the photo.
    • It is not recommended to have the strips thicker then 2mm.
    Saving and collecting the little gold emblem could make you some money in the future.
    Clifton Linne - 답글
  3. GIVE TOOLS. FIX FOREVER.
    GIVE TOOLS.
    FIX FOREVER.
    Spread the Fixmas cheer.
    • The distance you see in the blue circle is not recommended to be more then 2mm.
    • Cut the card into many small parts as seen on the photo.
    • It is recommended to have a box/tin to prevent the parts to fly anywhere.
    댓글 쓰기
    • Look on the floor and on the table and see if you lost some parts of the card
    • If you found some, cut them also.
    • See previous steps.
    댓글 쓰기
    • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
    • Recomanded min 2 places
      • Taking it to the neighbor will not increase security a lot.
    댓글 쓰기
결승점
다른 24명이 해당 안내서를 완성하였습니다.
Truls Zhong Konstali
회원 가입일: 2014년 05월 09일
1,316 평판
안내서 1개 작성함
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - 답글
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - 답글
Please correct some typo but yes you got the
Hiram Pabon - 답글
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Hiram Pabon - 답글
Rabitts take the hard drive and burnt it to a crispy ashes.
Hiram Pabon - 답글
Fire destroyed anything
Hiram Pabon - 답글
Destroys anything
Hiram Pabon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 120
전체 시간: 9,233
