주요 콘텐츠로 건너뛰기
How to determine Mac shutdown causes
  1. How to determine Mac shutdown causes, Open Terminal.app: 1 단계, 이미지 1개 중 1개
    • Open Terminal.app
  2. How to determine Mac shutdown causes, Listing previous shutdowns: 2 단계, 이미지 1개 중 1개
    • Copy and paste the following command in your Terminal window:
    • log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
    • The "24h" portion of the command can be changed to any number of hours, depending on how far back you need to see.
  3. How to determine Mac shutdown causes, Determining Shutdown Causes: 3 단계, 이미지 1개 중 1개
    • The previous shutdown causes in the timeframe you selected will appear as a list.
    • Common shutdown causes include 5 which indicates a normal shutdown, 3 which indicates a hard shutdown (i.e. holding the power button), and 0 which indicates the power was disconnected.
    • A list of shutdown causes can be found here: Shutdown causes (from George Garside blog)
결론
Done! You should be able to use these codes to further troubleshoot random shutdowns or other strange events.
Hit the button below if this guide helped solve your issue :)
다른 24명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
4다른 기여자 명과 함께
Jonah Aragon
회원 가입일: 08/05/18
5,672 평판
안내서 5개를 작성함
Experimax Coon Rapids Experimax Coon Rapids 회원
Business
3 회원들
안내서 19개를 작성함
14가이드 댓글
For me it says
kernel: (AppleSMC) Previous shutdown cause: -20
The attached PDF (and the internet) doesn’t seem to have any information about this code. What’s the source of the codes for the PDF? Maybe they have updated listing for shutdown codes.
Saurabh Shrivastava - 답글
we also have -20 as a cause and have no idea what it means. did you ever find it out?
octomobiki -
I also have -20 code of shut down after macOS 10.15.5 update with MBP 16inches model.
but no information at all….
赤月小黄泉 -
writErr = -20, /*I/O System Errors*/ its this error for code -20 .. Find all error codes here :- https://krypted.com/lists/comprehensive-...
UNKNOWN X -
Sorry , that was not related, check this one : - https://georgegarside.com/blog/macos/shu...
and, error code 20- T2 security chip initiated shutdown
UNKNOWN X -
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 117
지난 30일: 562
전체 시간: 104,023
