주요 콘텐츠로 건너뛰기
How to diagnose Samsung Galaxy A40 Charging Problems
동영상 개요
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 1 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 1 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 1 단계, 이미지 3/3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 2 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 2 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 2 단계, 이미지 3/3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 3 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 3 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 3 단계, 이미지 3/3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 4 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 4 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 4 단계, 이미지 3/3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 5 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 5 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 5 단계, 이미지 3/3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: 6 단계, 이미지 1/3 How to diagnose Samsung Galaxy A40 Charging Problems: 6 단계, 이미지 2/3 How to diagnose Samsung Galaxy A40 Charging Problems: 6 단계, 이미지 3/3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
결론
다른 6명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 50
30일 전: 256
전체 시간: 8,621
