주요 콘텐츠로 건너뛰기
How to perform a Hard Reset on the Nintendo DS Lite
필요한 것
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: 1 단계, 이미지 1/1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: 2 단계, 이미지 1/2 How to perform a Hard Reset on the Nintendo DS Lite: 2 단계, 이미지 2/2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 3 단계, 이미지 1/2 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 3 단계, 이미지 2/2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 4 단계, 이미지 1/3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 4 단계, 이미지 2/3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 4 단계, 이미지 3/3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: 5 단계, 이미지 1/1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 6 단계, 이미지 1/3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 6 단계, 이미지 2/3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 6 단계, 이미지 3/3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 7 단계, 이미지 1/2 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 7 단계, 이미지 2/2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: 8 단계, 이미지 1/1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Artem Ivat
회원 가입일: 02/05/20
2,709 평판
안내서 12개 작성하였습니다
Kid fixers Kid fixers 회원
Community
161 회원들
안내서 300개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 66
30일 전: 374
전체 시간: 9,530
